Oil Leak... will not go away!
DRZ32
Car: 1995 NA 2+2
So I have very recently replaced the RMS, Real oil pan seal, RMS retainer gasket, and PCV valves. Today, I found a very slight leak out the rear.
Is there anything I am missing?
ezb57e
Did you replace the gasket between the rear main seal RETAINER and the block?
DRZ32
Car: 1995 NA 2+2
Yes.
nissanfreak12
Car: 92 300zx 2+2 TT
Check your Cam covers, VTC Solenoids, and half moon seals. They are known to leak especially the half moon seals. Best thing you can do when resealing these is to replace the rubber half moons with BDE billet plugs. One of the best things I have done for sanity.
http://www.conceptzperformance.com/Cart ... 6.249.73.5
