uttadms31 »
https://forums.nicoclub.com/uttadms31-u246174.html
Sun Jan 04, 2015 7:39 pm
Hello All,
My 1998 with 235k miles on it now has its first (dripping) oil leak that was diagnosed to be near the front main seal. There's also some oil down the rear valve cover but it's not too heavy there yet. I usually get a few drops of oil near under the right control arm after the car sits overnight. There's also a lot of oil/grime near the bottom of the timing cover and along the cord to the oil pressure switch. I'm positive the leak isn't right at the oil pressure switch nor the lower oil pan, and most likely not the upper oil pan since oil doesn't seem to be beading near it. I just had a few questions. Thanks for your time.
1) Is there anyway to know whether the leak is due to a failed timing cover gasket/O-ring, OR a failed front main seal?
2) If it is the front main seal, can I remove the crank pulley bolt simply by using a breaker bar and pipe, along with a screwdriver in place at the flywheel ring gear (I don't own a impact, but do want to be able to take the bolt off and not strip it).
3) To remove the crank pulley, can I just use a prybar/screwdrivers, or is a pulley puller required?
