ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Tue Oct 28, 2014 6:57 am
With engine running, remove enough timing belt cover bolts so you can get it to open a bit at the top. Put your rag or hand at the crack and see if its getting oil flung onto it.
Common problem is for the VTC intake gears to leak. I've had this on my car and a couple of friends. Take timing belt covers off. Take timing belt off. Take intake gears off. Try to turn the front and back of the gear in opposite directions by hand. If you can turn it by hand, then the gear is bad.
