Oil leak
xyster
Car: '00 Prelude
I seem to have an oil leak in the oil filter assembly. After idling in the same spot of 15 mins or so, it leaves an oil spot about the size of a silver dollar. i read an old post where slw240sx mentioned the same problem, and possibly getting an o-ring from nissan. I couldn't find a post that told whether he ever fixed it or not. Is it just a standard size o-ring? I'm going to be working on the car tomorrow anyways (installing Tein HE's, witing turbo timer, etc), so I'd like to take care of it then. Also, I'm running redline 20w50 oil, and that stuff is expensive...I can't afford to dump it on the ground.
NeedCAforS13
Car: CA swapped S13 coupe
jon's problem is with his oil cooler I think, do you have an oil cooler down there? If not, try and figure out where exactly the oil is coming from. There is a gasket between the filter hub (where it screws onto) and the block. I suppose that could be leaking. There are also afew oil breather hoses down there, but I doubt they could leak enough oil to make a visible leak after afew minutes:)
Sean
xyster
Car: '00 Prelude
stupid question: the metal pipe coming off the back of the intake side valve cover (the one the angles sharply down), is supposed to connect to the fat rubber line coming out of the back side of the oil filter assembly under the intake manifold, right? Thanks to Venus, almost all my rubber lines were disconnected or cut when I got the motor. I just want to make sure I have this set up right.
NeedCAforS13
correct:)
Sean
xyster
Car: '00 Prelude
ok, cool. Is that rubber line supposed to have a one-way valve or restrictor or anything in it?
NeedCAforS13
not that I remember... the pcv valve is a one way valve I think, but its coming out of the back of your intake manifold, not the valve cover itself.
Sean
float_6969
Check your oil pressure sensor. It's right next to the filter. Mine leaks there. It's actually coming through the wires though and not the threads so I'm going to have to buy a new one, which is why I haven't fixed it yet.
xyster
Car: '00 Prelude
The oil pressure sender is gone, replaced with a fitting and braided SS line. That's not leaking, I've checked it several times.
float_6969
So does your oil light stay on all the time now? Thats not real safe...
NeedCAforS13
he might have an oil pressure gauge ryan:)
Sean
xyster
Car: '00 Prelude
no, the light doesn't come on at all. I have an Autometer mechanical oil pressure gauge.
