Oil leak
stebo0728
Car: 1993 300ZX, White, T-Top
Im in the middle of some work on her, and Ive had an oil leak for some time, but it doesnt spot. Rather it seems to leak somewhere above the alternator, and the alternator burns it off, what join would likely be the cause of a leak somewhere above the alternator?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Valve cover gaskets, cam seals. You need to correct that or else you'll be frying alternators left and right.
stebo0728
Well, since im rebuilding my lifters, I will already be replacing both the valve cover gaskets and the cam oil seals. Would that be the only joins of concern you think? Studying the drawings in the manual leads me to believe so, but I just wanted some seasoned opinions as to any other seals I may want to go ahead and replace while I have her apart.
awesomekasim
Car: 1991 300zx TT 5spd
are you sure its oil? The high pressure power steering line is notorious for leaking over the alternator
es.biggs
Car: 1990 300ZX 5sp NA
^^^ my thoughts exactly...make sure its oil, not PS fluid
robomatic12
Car: 1990 300ZX TT
As the other guys said, I would check into the HP power steer hose. Look in your power steering resivoir to see if the fluid level is low, you should be using ATF which is a red color. Look and see if the leaking fluid has a red color, it may be darker if its mixing with dirt too.
Check this out for more info+pics on HP hose.
http://www.pexcom.com.au/z32cms/e107_pl ... content.36
