BLKONBLKS14 »
https://forums.nicoclub.com/blkonblks14-u148041.html
Fri Nov 20, 2009 4:52 pm
I have a stock 95 240sx that i just bought and i did most of the general maintenance (i.e. belts, oil change, fuel filter, spark plugs...)and i started it up after and now there is smoke coming from right behind and underneath the first tube of the exhaust manifold closest to the headlights where it bolts up to the head. Does anyone know of any seals or anything i should check cause i cant pin point the source of the i guess leak. Didn't smoke AT ALL before the oil change. Should i try some LUCAS in the oil and see if that helps???? Its not drip from poring oil i ran the motor for 20 min and it was still smoking.it not much but ITS SMOKE!please helpthanks
