it looks pretty simple to me. youll need some liquid gasket and a way to get off the hard to get to bolts ie wobble socket. I dont think you have to do anything with distributor if you are just taking valve cover off. PICTURES ARE BACK FOR THAT TUTORIAL.advanceKEN240 wrote:thanks alot guys for all the support.... looks pretty complicated to do ....iono if i should do this by myself prolly have my mechcanic take a look at it, but i do appreciate all the help....thanks
You used blue RTV? Thats not good for valve covers or oil related items IMO, i know i know you're going to say its says its ok to use on the box. The blue ones are for things like water pumps and thermostat housings. The oil related stuff i recommend the Permatex Ultra gray or the expensive Nissan orange silicone. The reason is, the blue stuff is too soft when it cures and doesnt resist oil as well as the Gray one, the Ultra Grey is a stiffer version of the blue and is meant for valve covers, oil pans etc, it actually has a Nissan approved label on the back also for this type of use. The ultra gray has a different chemistry altogether, i bet that blue stuff is the one that smells like vinegar lol. The gray stuff smells like swimming pool chlorine.vancouverbc wrote:note clean off dirt and oil before replacing gasket or using liquid gasket
Install your valve cover- Put your gasket in the valve cover as shown in the picture.
-Apply RTV sealant at the semi-cricle "ditch" in front of the camshaft and also in the back as shown in the picture.
-Install your valve cover and tighten as shown below. Torque spec is around 7~10 lb*ft
Ahh i see...okvancouverbc wrote:Im not the author of that tutorial. Im just backing it up in case the pics die again.
I used Permatex red hi-temp for my water pump. I was planning on using it for the valve cover . I do appreciate feedback on these tutorials .
Although I hav ethe SOHC and not the DOHC in general valve cover gaskets are a good place to start if yo want to become better aquanted with your car and your tool box. Kind of hard to screw up and if you do make a mistake USUALLY all yo uend up with a leak like you started with.advanceKEN240 wrote:thanks alot guys for all the support.... looks pretty complicated to do ....iono if i should do this by myself prolly have my mechcanic take a look at it, but i do appreciate all the help....thanks
just the archtramp_drift240 wrote:why are there advocates of using liquid gasket for the valve cover?
isnt it better off to just get new rubber gaskets, theyre supposed to be installed dry.
the one ive got right now (92 dohc) ive used maybe 5 or 6 times, all ive done is dry off the gasket and the contact area on the head, then just bolt it back down to spec. havent had any oil in my spark plug holes or around the edges of my head.
i think its better off to just replace 'em and be done with it instead of getting all messy with liquid gasket maker.
I cant really visualize what the arch is. The fsm say there is a rubbler plug in the arch. according to fsm, you put rtv around plug. I assume the gasket interfaces with the rubber plug? maybe plug shrinks so you put rtv in that area. i have no idea.tramp_drift240 wrote:that diagram doesnt make much sense to me, to be completely honest.
still, havent seen any reason to use liquid gasket on mine. dry install means metal to rubber to metal.
Probably because you have a SOHC? , this applies to DOHC motors. I dont think the SOHC had those half moons.tramp_drift240 wrote:that diagram doesnt make much sense to me, to be completely honest.
its not directly compressed with bolts, no. but when you tighten all the valve cover bolts, the force is distributed through the whole contact area. which runs around the whole edge of the head.vancouverbc wrote:looks like the rubber plug is part of the gasket so it makes sense to rtv it as it is not compressed with bolts.
This liquid gasket on the half moon is recommended by Honda also, i remember this in the Honda FSM when i used to work on B series motors.tramp_drift240 wrote:Nah man, ive got a DOHC in my car.
i dunno, i guess it could be a good idea, but this is honestly the first time ive heard of it being actually advocated to use liquid gasket on it.
Excuse my ignorance, but what are those?nisssan-drive wrote: YUP... might as well just throw these bad boys in there!
