oil leak
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
on mine the oil is leaking down the oil pan, coming from behind the crank pulley....it only leaks when the car is running, and when i give it gas it leaks a lot more.... again it comes down from near the crank pulley and drips down the oil pan...
what is the leak coming from and how easy to fix??
180fan
Car: 89 fastback
hmm, I think a bump of the previous thread was sufficient. Probably your front main seal.
