oil leak?
240ss
I have 93 240 sx (130k mi) with a bad engine oil leak. I appears to be in the front of the engine(but is very messy to be sure). Any ideas and solutions?Thanks
drjohn
Clean the frt. of the engine and get it to the piont you can till where it's leaking. Could be the frt. crankshaft seal. The timing cover oil seal at times will leak between the block and timing cover. If that is the case with that many miles it's probably do for the timing chain replacement anyway.
