Oil leak problem, help!
Boosted_240sx
Car: 1989 Nissan 240sx w/ SR20DET
So i noticed about a month ago i was leaking oil from where the headgasket bridges between the oil pump cover and the head, not a ton just a little bit every now and again but i was wondering if it will be alright to not worry about it or is this a big problem and should be fixed asap. Also how hard would it be to fix this?
thanks in advanced for the help!
Dylan
Alisaihin
Car: Got two, see signature! :3
If your headgasket is leaking...just get it replaced. Never just let a head gasket leak go...cause that s*** isn't only keeping oil in place, it also seals the cylinders and coolant lines within the block.
Let it go too much longer and you're going to have more than just a mere minor oil leak on your hands.
