ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Fri Jul 22, 2005 12:18 pm
94 Q45, 158,000 miles, was looking under the car today and the oil appears to be leaking from the area that the transmission mounts to the engine, it's definetly oil. Is the rear main seal a common problem in this engine with this many miles? Is replacing it as simple as dropping the transmission and replacing the seal or what? oil leak doesn't appear to be coming from top of engine or near valve cover areas, Thanks
