leroy12 wrote:Hey guys I have had an oil leak everysince I switched to synthetic oil. First the valve cover gasket then the oil sending unit. Now after replacing both of those it seems the motor is still leaking right under transmission. Does thus point to the rear main or cold it be somthing else? Lmk asap plz. Oh also would$ 350 labor be about right for a shop to replace the seal while installing a new clutch?
First of all the labor price sounds, but the seal only cost around $15. If they are doing a clutch for you and you've never changed the rear main seal, then you might want to ask them how much are they charging you for the seal before you just okay it. Why are you using synthetic oil on this engine? Synthetic is too slippery and will find it's way out of yester-years engines, to include the CAs. Todays engines uses timing chains and are all sealed-up with silicone or whatever they use from factor, so they seem to do somewhat of a better job of retaining the slippery oil. You may want to change your valve cover gaskets as well as the end plugs or half-moons on the firewall side of the head and make sure you re-tighten the head with gentless or you'll crush the new gasket. Hope this helps.
