mutiny »
https://forums.nicoclub.com/mutiny-u53418.html
Fri Oct 19, 2007 6:54 pm
Ok I'm getting pretty frustrated with this damn car already....
anyways, its a ka24e sohc rebuilt. there is oil leaking somewhere, and i think its leaking from between the head and the timing cover. I cant really trace it, but it seems to be coming from that general area, and possible on both sides of the motor.
but then.... when i look on the ground where the oil puddle is, its milky light brown color, does that mean coolant mixed with oil? So i have 2 problems now? No smoke from exhaust or anything, doesnt overheat i dont think, so im hopefully ruling out bad headgasket?
i redid the front timing cover because i thought that was the problem with a coolant leak before and coolant mixing with oil (i thought the seal between the coolant channel from water pump in timing cover was bad) and made sure to do a good job with permatex gasket around the timing cover, but i started it up and oil is now leaking (oil + coolant im guessing by the look of the oil). Any idea on why the oil looks like that or where it could be leaking from?
