dcg129 »
https://forums.nicoclub.com/dcg129-u77311.html
Sat May 31, 2008 1:13 pm
I'm not a mechanic, however, I broke more than I fixed and paid dearly. Here are somethings you could check.
Don't buy those stop leak additives. It sounds like the leak is bigger than they could handle.Try a new filter. it may be warped or a pinhole leak. Highly unlikly, but its a cheap fix. While you are in the area, clean throughly with some degreaser or go to the car wash and try spraying in that area . make sure you don't spray near electrical wires, etc.. You might be leaking from a valve cover or oil pan.
Over tighting the covers/gaskets is just as bad as being too loose.
Go to a parts store and they should have a red die additive that will show up to ultra violet light. You add it to the oil and after a day, bingo you see the oil leak clear as day.
The only other two areas are the main bearing and rear seal, but it doesn't sound like it is coming from there.
Keep us posted dcg
