Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Aug 05, 2005 2:54 pm
No problem areas there, but it sounds like a bad crank seal. No big deal. You take a break-over bar and a 24mm socket, get a piece of corrugated pipe. Slide the pipe over the break-over bar, and put the socket on the center nut in the pulley. Jamb them against the ground on the power steering side of the engine, get in the car and bump the starter (just for a half second or so). It will likely make a noise that will break your heart, but it's okay, that bolt is just REALLY tight. An impact will do this too. Once you have the bolt loose, grab the pulley with both hands, and shake it back and forth. It should wiggle it's way out, but if it does not you can probably rent a 3 jaw puller (DO NOT use a 2 jaw, you will warp the pulley) from your local parts store. With the pulley out you will see the snout of the crankshaft along with it's woodruff key and the oil pump drive (the oil pump is run by a goofy metal drive on the crankshaft and is built into the timing cover). When this seal fails it leaks like crazy since it is pressurized oil that is leaking out. The seal can be purchased separately, but I found it was cheaper (at least at Advance) to buy it in the set for the timing cover, and just through everything else away. Hook the oil seal or very carefully, pry it out with a screwdriver. With the new seal, slather it all over in lithium grease, and place it in the hole. Use a seal driver or appropriately sized socket (use flat ratchet side) and hammer to drive it in. Nissan has some sort of goofy spec for depth, and they tell you not to bottom it out. FUNK THAT! Do it anyway, this will put a new groove in the pulley, so you don't need to worry about it sealing, and if you are putting on the Orthodox or ASP pulleys, (at least the ASP will not fit if you don't bottom it out). Make sure to deburr your pulley, and clean it up before you reinstall. And now is a good time to put on even more lithium (there is no such thing as too much in this case). If it is a manual, put it in gear (lower gear the better, reverse is good too) and set the parking brake as tight as you can. Tighten the bolt as tight as you can, if you have an impact, zip it on and hold it for 3 or 4 seconds. You're done, you can have a beer now, just don't go driving afterwards.
