ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Sat Apr 07, 2007 8:01 am
Its probably a blown turb. Did you check for shaft play? When my T-25 was bad there was oil everywhere inside the hotpipe.
Large amount of blowby can also cause this but something has to be significantly wrong with your piston rings to cause lots of oil to form in your intake piping.
If your internals are fine and everything is in good order, you should not have much blow by. At least you shouldnt see oil in your intake piping.
