SiNFuL »
https://forums.nicoclub.com/sinful-u7660.html
Sat Nov 15, 2003 8:41 am
well sob. I jacked up the car today and cleaned up all the oil. I let it idle till it was warm and at a solid 750rpms...then came the high rpm test. I did a few 5500-6000 rpm runs and a steady 4k. NO OIL LEAK AT ALL! wtf? =). Its kinda good, but Im afraid its gonna keep happening on and off. I checked around the oil filter and there isnt much oil at all. It's mainly around the oil pan and crank pulley, and I think theres some behind the trranny but that just might be really shiny grease(I have a lot of that under the car, but it always has). However, before I did the rpm tests I figured that last time my friend put the oil pan, he put it to "guessed" torque, however he's super intelligent w/ mechanics of car so i figured it would work, and it did. But I bought a trq wrench yesterday($45...jeeze la weez) and decided I might as well torque em up to spec incase they were loose or something. Well I failed to read the 5-80lb trq range and tried adjusting it to 3.651(measuring less than 5), but I didnt realize that it would only work above 5; i figured the markings just started at 5 as a basic place to start. Anyways, I kept tightening it, and it felt loose, so I took my wrench off and out came the top half of the bolt. Man that sucked. However the other what, 15, are still on there so it hsouldnt be falling off anytime soon. I'm bringing it into a shop wed. for a whole bunch of stuff...how much does EZ-outing a screw cost. I have the EZ kit, but I was afraid if I kept trying to fix it, i'd be a crapload worse. Any ideas on this? Is it expensive for a shop to remove half a screw? Still trying to figure out the leak too. On a happy note, I'm installing my PIAA Super Extreme white H4 bulbs today in my H4 conversions I just got last week. Thanks for all the help guys, any further info, comments are definately welcomed!-Galen
EDIT: Last oil change I did I put in 4.5 qts instead of 4 on accident. I checked the oil today and it was full; so maybe the excess oil was letting out.
