oil leak help
jkilby18
Car: 1991 300zxtt
well i jus reinstalled my motor with the new turbos and ive found an oil leak... Its leakine fron the pass. Side oil feed.... The small block that comes off the block that the line connects to leaking between the block and the small oil block.. My question is can i fix this with mh motor in the car? If so what would be the best way.... Id love some advise before i try tackeling it
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I give up, can you? It sounds like you are referring to the banjo bolt IIRC you might have to remove the alternator but whatever is in the way can be removed in the car, the turbo can be removed in the car it's just quicker and easier to pull the motor
