I think you and I need to get together and, well, drink. I am a big fan of drinking and posting on the internet.ard wrote:i was completely wasted when i wrote that...
ard wrote:try not to push the new seal where old seal was, because of scrapes on the crank. putting new seal where old one was is the main reason why new seal leaks - scratches on crank makes new seal leak.
thats basically the same thingard wrote:what i meant: do not put new seal exactly into the same place where the old (leaking) was. there are scratches on crank (my blind guess), so they make new seal to leak oil.
at least you understand what i'm trying to saysjbsuperman1425 wrote:thats basically the same thing
progman wrote:Are you saying to try to put it slightly more forward or back in case the crank is scratched?
