KJSmitty »
https://forums.nicoclub.com/kjsmitty-u105196.html
Mon Dec 01, 2008 5:22 pm
I would have to agree with Kerrton,
Normally I take responsibility for all of my actions, but I find it hard to believe that 1/2 qt over would cause any issues. Way back in the day I actually put 8qts of oil in a nice old lady's 4 cylinder Nissan Sentra. Besides running rough and smoking it caused no lasting issues.
1/2 qt would not increase oil pressure nor should it increase internal crankcase pressure enough to cause an issue. The main worry is aerating the oil or over oiling the pistons/rings. Given typical safety margins this would normally take more than an extra 1/2 qt etc.. But I'm no expert on the current Nissan V6 and crankcase either...
I wouldn't doubt if the leak is coming from elsewhere or completely unrelated. That's why I agree with just taking it to your dealership and telling them nothing other than you returned from a trip and now have an oil leak. Now, if they check it out and call you and ask if you ever overfilled the crankcase - because your leak is typically caused by that mistake,,, then it's up to you to come clean...
Best of luck - let us know what they find.
