Oil leak from unknown part, 01' QX4. Quick help
Fieldy211
Car: 2001 QX4
I have a very moderate oil leak from the passenger side of the engine, leaking down onto crossbrace. It seems to be coming from the device that is bolted onto the side of the oil pan, which the oil pressure switch is located on. My question is, what is that round part AND the two lines coming out of it? Are the seals known for going bad in there, and would i be able to replace them myself? Im automotively inclined... also let me know of any other things i should check.
Thanks for any help. Need to get this resolved soon.
MIKE
Fafdawg
Car: 2001 Infiniti QX4 4x4 (Silver) & 2006 M35X AWD With Tech package. (Blk on Blk)
I have the same oil leak also.... Please, post it if you fine out were the leak is. I'll do the same. 01' QX4
timmack
Car: 2002 Nissan Pathfinder SE
heres a related post, not much of a definite answer but its along the same lines..
zer...62560
Fafdawg
Thank you for your help. The past 2-3 days, I haven't seen any leak on the ground and my oil level is ok. I'll let you know if i fine the answer. Thanks
Tomzr2
Car: 2001 Pathfinder 4x4
Same problem, Small leak around part on the lower passenger side of motor above cross brace. Is this the oil cooler for sure? If so what is leaking a gasket or o-ring. Does anyone have an idea of the nissan part# called the local dealer they had no clue what I was talking about.
