Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Mon Sep 17, 2018 11:07 am
The head gaskets extend to seal between the large cover, and the two smaller timing covers. If the head gasket is damaged, like what happened to me, one can cut a cork gasket and glue it to the small cover, then reinstall the large timing cover. I suppose one may remove and replace only the small, I do not remember the details. My issue was on the opposite bank of what you describe..
I messed up my head gasket extensions by reinstalling large timing cover without removing the oil pan. The proper way to remove/replace timing cover is to remove the oil pan. If it is not done this way, the risk of damaging the head gasket extensions is great.
Voice of experience here, I messed mine up, and had a hard time fixing the oil leak between the large and small covers. I had leaks until I removed all covers, cut and RTV'ed 1/16" thick cork gasket to the small pieces, then reinstalled small, then large, then the oil pan. To the best of my recollection, it is possible to remove valve covers, and remove top timing covers, though IIRC timing chain tensioner travel is affected by the covers, extreme caution is advised to not loose proper timing when servicing the covers.
So long story short, remove oil pan, then large TC, wire the timing chain to hold tension, remove the leaky upper cover after removing it's valve cover, fashion/fasten 1/16 cork gasket in place of missing head gasket extension, then reinstall by reversing your steps. Simple, right?
