I agree even if you found one of the bolts loose on your seat I'd make them fix it; oil leak on a brand new car with 3,000 miles is insane, so put them to work. I also agree with waiting till more builds up, so they can't give you the run around saying they didn't see a leak while trying to make you fill dumb.wade001 wrote:wait a little for it to build up again and take it to the dealer and claim ur warranty. don't try it yourself when you can have them fix it like they should
As in the rear main seal? If so they will have to pull the engine/trans to fix that, and the steelership may get a big case of denial. lets hope not.wade001 wrote:another thing it could be is the bell housing after looking at that pic better, the flex pipe is under the transmission right?
yupBamaCoupe wrote:As in the rear main seal? If so they will have to pull the engine/trans to fix that, and the steelership may get a big case of denial. lets hope not.wade001 wrote:another thing it could be is the bell housing after looking at that pic better, the flex pipe is under the transmission right?
I thought it might be that, sometimes this happens, 100% of the cars that come out of the factory are not always perfect. it happens even if it is rare. i wouldn't blame anyone for this. it is unfortunate this is happening but at least they'r going to fix it. it shouldn't take too long to fix thought, a week at the most. they might just replace the motor but who knows. but im glad the problem is solved and they'r going to fix it though. keep us posted.trigger_storey wrote:Dealer took a look at it today. They basically diagnosed it as the rear main seal with just looking at a few things and not tearing into anything. Of course I had to take it to the dealership I bought it from which is an hour away cause the pos dealer here in town wont give me a rental or loaner car because I dont have the extended warranty that covers rental. For all instances in which a car is 5 months old with only 3100 miles and is leaking oil, I think there should be some kind of clause or something to work out. This is not my only vehicle but its impossible for me to take the wifes car because she uses it to take the kids to school and then herself to work. Kind of rediculous in my opinion and even though Id like to say its the local dealers fault, Id have to say this is the one time I have lost my faith in nissan. Only once did my F250 ever have to go in for warranty work, and I had a loaner for the 5 days it was there. So kudos to Ford for the factory loaner program. Needless to say luckily the owner at the one I bought it from is a stand up guy and he is lending me one of his used cars while mine is in their " temporary custody". I talked to him directly on the phone and he said not a problem. So we will see what happens and hopefully this doesnt take forever and they let me know everything is fine besides that. The tech said most likely it is a manufacturers defect and had been slowly leaking the entire time Ive owned the car which would explain the residue since new. I know one thing. Im gonna be keeping an eye on it for awhile once it returns to me.
