marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Thu Jul 21, 2011 7:11 am
The simplest thing is to replace all of your seals and check your intake cam gears for leakage (yes, they do develop leaks as well). I would replace both main seals, cam seals, turbo oil return lines and check the feed lines for blockage. Also, pull the VTC's and seal those with new RTV, replace the valve cover gaskets and the grommets for the screws. I also put a small film of RTV on the valve cover gaskets where the contact the head to help keep the seal when (not if) the screws loosen up. You can't re-tighten most of them with the plenum on.
Also, check all of your hoses, replace water lines, do the TB water bypass if you haven't already.
