JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Mon Jun 25, 2007 3:56 pm
Oil pressure sending switch, located on the bottom of the oil filter pedestal. Very common to leak.
Other common leaks (not in that area) are rear main seal, oil pan gasket, then front main seal.
Best thing to do is get a can of brake cleaner, spray all the oil off, crank the car up, and see where its coming from.
