MojoMan wrote:I would have to agree with 96s14se. You dont even need rtv at all. and from nissan those gaskets are not so expensive that even a homeless person couldnt afford. Do it right and get the o-rings from nissan.
But you do need rtv..... for the half circle lobes on the gasket
As far as that noise go you may have some increased wear in the lifters. Not a potentially big problem but they will get noisey as they wear over time. You could always yank the cover off and break out the feeler gauge to make sure. Could also be just varnish build-up and not allowing the cam lobes and or lifters to slide as freely. I have the same noise and it recently has gotten louder. My clearance is good as I just checked it a cpl months ago, so Im going to try this flush (sorta like industrial sea foam, but when you dump it into the engine it states not to drive it, just let it rev at 2k or so for so long, and drain the oil after) my friend uses at the local nissan dealership. Im not too concerned with it and think this will solve it.
Take a LONG screw driver and place the handle to your ear and the tip to various parts of the engine to determine exactly where the noise is comming from.
