Oil Leak around exhast manifold!!!
mexicanS13
Car: 91 240sx COUPE
So for a while the car has been having a hard time turning on when its cold, also the smell of burnt oil, and lots of smoke when i gas it. I did the oil change yesterday as i've only had this car for 3 months, i notice there was fresh oil around the exhast flange of the 3rd pipe on the exhast manifold.This can explain the reason for the high Nox doring the smog check. the motor still halls a** and idles good so i have a feeling its not a bad block, but a blown gasket. I just want to make sure and get all you guys opinion on this. If you need a picture of it let me know and ill put it up. Ill appreciate your help
lbreevesii
Car: S13 hatch LeMons project - Kaputzen!
BMW E30
Oil could be coming from a bad gasket, bad valve steam seal, or even a ring issue.
mexicanS13
Car: 91 240sx COUPE
lbreevesii wrote:Oil could be coming from a bad gasket, bad valve steam seal, or even a ring issue.
Thats what i was starting to think of last night, is there any way or test i can do to know what exactly it can be
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
Have you compression tested motor? Does the oil smell like gas?
mexicanS13
Car: 91 240sx COUPE
fiznowler wrote:Have you compression tested motor? Does the oil smell like gas?
I will rent a compression tester this weekend, and it smells more like oil and but it can be a mix of both. Its only on the 3rd flange from the exhaust manifold. i will unbolt the manifold to try and get a better look. i might drop some sealer to see if it holds for a while just to save money and fix the problem
