So I finally replaced my broken rb20 t3 turbo for a subaru td04l turbo, the swap turned out great (made a t25 to td04 adapter), car runs much better, though there are some idle and cold start issues:
1) I noticed some oil under the car, upon closer inspection the left engine mount and the block is covered in oil there - like it's leaking from the oil supply for turbo hole on the side of the block (stock hardline and fitting where replaced with a new high pressure hose with a banjo fitting and bolt). what could be the problem, provided that the bolt was screwed in very good and there where no leaks up until today (for 2 weeks or so)?
2) car won't start when engine is cold from time to time (won't start after the night). tried replacing the idle valve - nothing changes, unplugging the connector doesn't do much either (fuel pump works, engine is cranking, but looks like no spark). any ideas?
3) on idle during warming up tach goes back and forth from 1.5k to 2k rpm, then sets down at 1.2rpm and after hitting the throttle goes down to 900 or so rpm. is the idle valve broken or some other problem?
any help appreciated
