Yea, the car has been leaking since day 1.J30tChumpCar wrote:There is a possibility it was damaged on installation, it would have leaked immediately.
nothing on the sides of the engine. its just in trans area. there is oil on the bottom lip of the rear part of the oil pan.t.mcginley.jr wrote:Is there any oil on the back or sides of the engine? or just on the trans/bellhousing area?
Well basically since you know its not coming from up on the engine somewhere (i.e. valve cover gaskets, etc.) then it's probably your RMS. There's nothing else back there that would cause an oil leak. Like you suggested, it could have been installed in the retainer wrong. There's also the possibility that the crank had a deep enough groove worn in it from the previous RMS's that it isn't sealing properly with the new one. They sell thin sleeves the go over the end of the crank for this problem, but it's kinda late now.crazybear wrote:nothing on the sides of the engine. its just in trans area. there is oil on the bottom lip of the rear part of the oil pan.t.mcginley.jr wrote:Is there any oil on the back or sides of the engine? or just on the trans/bellhousing area?
well i bought the car from a friend with a blown motor (blew the piston rings). he told me he replaced them less than 5k miles before it happened.t.mcginley.jr wrote:Yepp, definitely a possibility. These engines are fairly sensitive when it comes to their pcv valves (unless you bypass them, but that's another story). When's the last time they were changed?
Same, my VTC solenoids and intake valve covers were leaking oil after my rebuild. I didn't tighten down the covers enough, which made it leak from there AND around the solenoids because the RTF didn't seal good enough.ThisIsSparTTa wrote:Most likely RMS it sounds like. If you google, you'll find LOTS of people that had to do them 2-3 times to get them right. A lot of people will recommend using a little RTV on the outside. I think I may have a slightly leaking RMS after my rebuild, but I need to finish up other leaks first to make sure.
Also, do a double check from up top. Find the HIGHEST point you can find oil coming from. 2 of my really bad ones were surprisingly the VTC solenoids. Not sure how I borked that (I previously did Valve Cover gaskets with no problems), but they were both leaking a good amount down the back of the engine and onto the transmission.
