dbgeek »
https://forums.nicoclub.com/dbgeek-u35189.html
Thu Feb 09, 2006 4:43 am
My leak was coming from that oil cooler. It turns out that the sealing surfaces were coated in oil residue. I cleaned the surfaces, and applied some Hylomar to thr o-rings, and the leak is gone.
The cooler is held on by a single 17mm bolt/feed tube. In order to get a wrench on the bolt, I removed the front sway bar mounts (let the bar dangle from the end links). I didn't remove the hoses clamped to the cooler, but still had enough room to get in there with some cleaner and a brass wire brush. Be sure to clean all 4 o-ring surfaces: 1 on the bolt thing, 2 on the cooler, and 1 where the cooler mounts to the engine. Once it was all cleaned up, installation is the reverse of removal . Remember that the bigger o-ring has some geometry for lining it up, and there is a tab that locates the cooler.
Good luck!Pete
