oil jet/ ball valve/ check valve
sydwayz
Car: 1992 nissan 240sx
i need this little part that goes in the deck of the block it located on the passanger side of the block more twards the firewall does n~e one have one or even know wtf im talkin about
ilovecoupes
do you happen to have pictures?
sydwayz
sorry no pics it goes in the top of the block before u put the head gasket and head on
float_6969
What is this thing's purpose? Where exactly is it located? I don't remember anything like this in my engine. Could lacking this cause the problem I'm having with low oil pressure and perpetually ticking lifters, no matter what I do?
sydwayz
well when i first took my motor apart it had this ( oil jet/restrictor ) thing in the deck of the block i took it out to get the deck machined. then when i was putting it back together i didnt reinstall it ( cuz im an idiot). what this part does is that it restricts oil being pumped to the head. not having this installed could give problems oil presure problems in ure case it is a restrictor and restricting the oil could build more pressure? in my case im getting blow by so ive also been told this could solve my problem. DOES ANYBODY HAVE 1
float_6969
I don't have one, but can you describe what it looks like? Is it just like a ball bearing a spring? Was it pressed in the block? I'm about 90% sure I don't have anything like this in my block or head. I have low oil pressure and I can't get my lifters to quiet up.
superJoy
Car: 1989 RS13
I was able to find the Nissan part number using the FAST manual BioSehnsucht hosts on his website (impactblue.org) The part number is 11036D4200, which yields 'JET-OIL CYLINDER' at onlyfactoryparts.com at a price of $0.65.
This thread scared the **** out of me at first, as I didn't remember this part during the assembly process at ALL. Looking through my pictures of the block before assembly it looks like it was decked by the machine shop while still in place. Uh-oh. I must not have noticed it, as it looks like it was pressed in or something serious. Well, at least it's there. I'll have my fingers extra crossed on start-up, lol.
sydwayz
yes yes jet oil thats what nissan told me but they dont make them n~e more and u cant get the 0.65$ part N~E WHERE in the usa brand new. most people probly never noticed it and got the deck machined while it was in there. yes they r sumwhat pressed in but u can get them out. it looks like a 1/4 inch wide cylinder with a small *** hole in it. go to this web site here is sum performance ones for a skyline http://www.japaneseperformance....html
ilovecoupes
so this little number?
Modified by ilovecoupes at 9:28 AM 12/20/2007
superJoy
Car: 1989 RS13
Yep, that's the thing.
ilovecoupes
wow, i looked on my block. And it is just like sydwayz said.a small pin hole right in front of a head bolt.
I don't see what its purpose is. Like, what could that small hole accomplish?
sydwayz
yes that part ( ilovecoupes ) im so happy u pulled up that diagram dude. from what im understanding thats where the head gets all it oil from. does anybody have a junk motor or block or 1 of these i could buy im stressin out
sydwayz
nevermind i just spent a day of my life and 300 dollars to get a motor just for a 68 cent part WTF
float_6969
sydwayz
ohh yeah thats it
float_6969
Since that's my block, I guess that means I've got one then.
Back to the drawing board.
sydwayz
do u have a fully built motor float? what comp pistons r u runing?
NissanTouge87
Car: 1992 CA18 S13 hatch, 1992 pignose nissan pickup
BTW, just so you guys know, the RB guys, noticed that while sustaining a high RPM for long periods of time.. IE: nurburgring..haha, but curcuit racing, drifting, just being a d!ck on the highway that too much oil flows into head
since the drains arnt exsactly the best, you basically end up with ur valvecovers being the oil pan..symptons can be A LOT of "blowby"
Our motors, suffer the same design paradigm
What the RB guys have done, is that rear oil jet, theyve completly blocked it off. It will result in higher oil pressures and maybe louder valvetrane at idle, but if your gonna keep 'er at 8k for a while, this might be something worth looking into.
Also, on that note, the rear most lower valve cover breather on the passanger side of the block, closest to the intake manifold, the hard line that the rubber hose connects to, can get gummed up, so if you take this off and clean it, ull have less oil drainage problems,
Something to consider if you're using your CA for motorsports
EDIT: on second note, it doesnt look like we HAVE 2 of those like the RB guys, but on the same note, getting a smaller orifice will do the exsact same thing.
float_6969
sydwayz wrote:do u have a fully built motor float? what comp pistons r u runing?
Custom compression forged pistons from CP at 83.5mm. The compression is about 10:1. It was supposed to be 9.5:1, but I recently found out that I sent them the wrong piston to copy, hence the hellacious dome.
NissanTouge87 wrote:BTW, just so you guys know, the RB guys, noticed that while sustaining a high RPM for long periods of time.. IE: nurburgring..haha, but curcuit racing, drifting, just being a d!ck on the highway that too much oil flows into head.
I've considered this, but it does it at idle, crusing around town, on the highway. The lifters always tick.
