WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Jul 30, 2004 3:56 pm
Not that stupid Ckwik, my usually smart friend, seized his fully built RB25 and trashed his 2000 some odd dollar HKS GT3030 tubo by never putting in oil. While he was outside the car inspecting for oil leaks...lol...and setting the fuel pressure and the letting the car warm up, he toasted the it. What really hurt was the lack of assembly lube, if he used it, it may have survived long enough for him to figure it out.
Anywho, check your oil. If you have oil, remove the line and blow through it if it's clear and you have oil, then you should be good. Unless you removed the oil pump feed while the pan was off or somthing. Start the car and see what happens.
WD
