Oil in Throttle Body
BoomSlang240sx
Car: 1991 Nissan 240sx
I have just replaced my valves and valve seals in my KA24de and now whenever I try to start my car, oil is being thrown back into my throttle body and intake pipe. My compression is perfect so I don't think that it is a crack anywhere but right now I am just trying to figure this thing out. Any help is welcome.
Thanks for looking.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Worst case scenario piston rings. Did you check the valve guide gap? My motor did the same thing when I started cranking up the boost. I just rerouted the valve cover tube to catch can instead of the inake and was good for another year and a half. That's when I had to rebuild the bottom end, car was smoking hella bad.
BoomSlang240sx
No but I will try that. Anything else?
shiro_neko
check your PCV first. if the PCV is not able to suck out all the blow-by gas it comes out in the blow-by hose (the hose between the valve cover and air cleaner pipe) along with the oil.
BoomSlang240sx
Thanks for the ideas:) Hopefully it is something small butif not owell. I will just have to keep on keepin on.
