Post by 240sxed » https://forums.nicoclub.com/240sxed-u28683.html Sun Nov 06, 2005 1:52 am
Post by Carl H » https://forums.nicoclub.com/carl-h-u9196.html Sun Nov 06, 2005 9:08 am
indeed, it can be quite normal to have oil on the threads if the valve cover gaskets have gone down the crapper, or if you used antisieze before you put the plugs in (which you should have).Kamin wrote:BIG difference hehe.
Post by 240sxed » https://forums.nicoclub.com/240sxed-u28683.html Sun Nov 06, 2005 4:27 pm
Carl H wrote:indeed, it can be quite normal to have oil on the threads if the valve cover gaskets have gone down the crapper, or if you used antisieze before you put the plugs in (which you should have).
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
