+1Vedoman wrote:blown headgasket
+2Vedoman wrote:blown headgasket
Well should I replace anything else while its opened up?Shusaka wrote:you can expect it to run great right up until the time of its untimely death, do yourself a favor and replace the head gasket its a 6-8 hour job for someone who hasnt done one before and it prolongs the lifespan of your car as opposed to having yet another "SR20DET Swap Ready" ad in the classifieds
This, but check the link below first, to see if it's a TSB. If it's a fairly common problem, it usually is, or better still, a recall. Neither the BHG or this quoted answer are technically wrong at a glance of the problem, but you'll want to be sure about which it could be before you start digging into them. Well, unless you have more money than Bill Gates and more spare time than a Wal-Mart greeter...carps13guy wrote:if its a sohc, ive heard its a common problem. my previous 240 had this same situation. the coolant looked like chocolate pudding when cold, but my oil was fine. my mechanic looked at it and said that the chain gets loose and wears away at the head, it puts a tiny weep hole into the coolant system, and oil gets into your coolant. i thought it was the weirdest thing, but thats what it turned out to be
Ok i found it but what does it mean? Can i go to the dealership and complain?del82 wrote:That's interesting....worked when I linked it...next!
EDIT: for some reason...making it as a hotlink changes the domain name to nicoclub...
EDIT 2: To hell with it. Google Nissan TSB, its the first link. What a retarded way to cover up rival forums
deffenitly head gasket if u didnt ave the time to do that u could change ur oil and coolant every other day and other than that personally i wouldnt run the cartrainwreck wrote:It is the ka24e. Then I guess I might as well replace with a DE. What parts should I replace before putting a used engine in though? And can I use my spark plugs and wires? And fuel injectors?
