maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Fri Jul 22, 2005 4:37 am
On VH41DE, the air flow is from top to bottom on the filter, opposite the VH45DE bottom to top. I was thinking along those lines, but it would be difficult for fresh unused oil to accumulate there.
How does the feed assembly to the MAF appear? Should be oily also if it ran down from the PCV.
James has the most plausible explanation. Inspect the intake path (check the resonating chambers especially), clean, and report back after you monitor for a few miles.
