oil in intake manifold?
Fenvy
Car: 2005 350Z Base 6MT
I installed greddy intake manifold over the weekend, stayed up all night for a saturday morning final then slept for 18hr straight....
anyways, I took 2 pics, shows there is evident of oil in stock intake manifold, is this normal?
SeVa-S13
Car: '05 GTO 6spd
Get a catch can.
DriftFactory
Car: Evil S13
Some oil in the intake is normal and it can be corrected with a catch can. There is a breather hose from the valve cover that allows oil to travel into the intake. a catch can does just what it sounds like, it catches the oil before it gets a chance to get into the intake. If the oil leak is extreme, you may have a blown turbo. Look at the turbo charge pipe coming off of the turbo outlet. If there is oil there, you may have a problem. If not, a catch tank should fix it. We have quite a few available and I'll link them below.
http://www.driftfactory.com/in...83_97
