oil in exhaust
IanS13
my daily driver, started smoking about 2 weeks ago after i removed the converter. now i notice oil in the exhaust tip, what's with the oil.
Nexus9
Car: R33 GTST VSpec Skyline
waht color is the smoke?
nametakennow
Car: '06 MINI Cooper S
How's your turbo feeling? Is oil like spitting up out of the tip? Is your oil level really low?
If so, you just sheared the rod that connects the compressor wheel in the center. Well, that's my guess... my bro did that to the K02 turbo on his 1.8T, so now he has a K03 .
Nexus9
could also be dodgy O-rings or one of the head gaskets about to go.Is it overheating at all, is it misfiring a bit?
w1ngzer0
Car: Pfft. i don't own a box
a.) head gasket (not about to go)b.)valve stem seals
Mr1der
oh knows!!!
the dreaded blowby....
there's a handful of reasons for it...hell, I think it could come from the turbo too....
nametakennow
If he's losing a lot of oil, fast, and his turbo isn't boost right, then my money's on that.
Of course, he could be lucky and it's a headgasket or something. Dead turbos are expensive.
Mr1der
he could always rebuild it himself...
most places will rebuild (assuming the housing walls and the turbine aren't wasted) for around 300.
if he's got oil coming out the tail pipe like that and not just smoke, I'd bet it's the turbo...I'm far far far from a mechanic though
IanS13
sorry guys the question is for my beater my turbo car lets out a verry little puff of black inbetween shifts. but my beater smokes when i let it idle no smoke but after idleing for a while when i hit the gas big puff of white smoke comes out, oh and by the way this car has 242000 miles on it
Altiman94
Car: 1989 Nissan 240SX
I would start by doing a compression test. After you do that, pinpoint where it's goin to by doing a leakdown test. That'll give ya a pretty darn good idea where the oil is coming froml
