oil in cylinder #6
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
I did a spark plug and coil pack change on my M with 133k miles on it after I had the 90k mile tune up done a couple of years ago at the dealership only to find out that they did not change the plugs at that time. anyway I got NGK plugs and coil packs and read the how to on how to change the plugs on the M, even though I have done several tune ups on my acuras over the years. Everything went smooth until cylinder #6 ( driver side plug nearest the firewall), when I pulled the plug there was oil on the sleeve. not a lot but enough to coat the old plug, I tried to get as much out as I could before installing the new plug and pack. my question is has this happened to anyone else while doing a tune up? I know some of the oil got into the engine when I started it up smoke came out of the exhaust, so I assumed it was burning it off.
Ilya
I haven't had that happen but if you have access to the exploded view of the motor, my guess is there is some type of o-ring or gasket for each tube...maybe that one is bad?
steve_c
Car: 06 Infiniti M35x
From your description, it sounds to me like one of your valve cover tube O-ring seals (I think that is what they are called) is leaking.
From previous post recollections, these seals are not available separately & require replacement of the valve cover itself. (The new valve cover comes with the seals, not cheap, and the cover R&R is a tad labor intensive!
I changed out my plugs at about 100k, and noticed I had a few leaking. I do believe #6 drivers side was the worst, as on yours. I recall some leakage at #3 & 5 tubes as well.
I did not address the issue, I have 129k miles now, I do not see or have any signs that the problem (oil leakage) is getting any worse.
I do not plan on changing the covers out unless oil loss becomes a problem.
If you search, you may find specific info from those that have tangled with these leaky seals.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
the valve cover is pretty expensive. the job is not bad but will require some patience. if you need a valve cover, I do have one. let me know
EdBwoy
Someone says there might be hope:
post6775969.html?hilit=Tube%20seals#p6775969
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
thanks for all of the replies I test drove the car today no burning or smoke and she sounds so much better with the new plugs and coil packs, and the Injen CAI I just installed. I will monitor the cylinder and if no more issues arise I will most likely just ride it out since the car only moves maybe 1500 miles a year or so.
