DuckyD »
https://forums.nicoclub.com/duckyd-u37392.html
Tue Feb 16, 2010 9:10 pm
The oil comes out of the BOV at WOT, or when he/you lets off and the BOV vents?
If the T that comes off of the valvecover is not routed back into the intake, and you have oil in your intake/BOV, then it is likely your turbo starting to go. This is not normal and not a good thing.If the T from your valvecover is going back to your intake, then it could (still) be your turbo or it could be blow-by being extacted from your crankcase and valvecover. Either your turbo is (still) starting to go or your rings are starting to give out. Either way, not a good thing.
It is all depends on just how much oil.
