nzmoman wrote:if your really serious about it order a case from somewhere. you will need more in a month or so depending on how you baby your car.
Also if you havent been running Zmax, you should. It is very nice to turbo motors and because its in the oil it can also improve turbo temps and seals as well.
I was just reading about Zmax and it says it's not an additive to oil, but then it mentions something about absorbing into the metal???? Seals better??? It mentions both of those but it does not tell you how it does that. I think it's the marketing and mental thing making consumers think that it has improved something but it really has not...I've never used it and including other millions of people and their cars are still running tip top shape.
Stick with good oil and you don't ever have to add anything!
Modified by S13240 at 4:26 AM 6/20/2006
