USMC5811 »
https://forums.nicoclub.com/usmc5811-u215192.html
Tue Jun 11, 2013 8:09 pm
So while changing my spark plugs today I noticed that the coil pack on the right rear (I believe its cylinder 5) had a very small amount of dried up oil on it. Upon further investigation i noticed that I could see oil between the valve cover and the spark plug well. Once i got the spark plug out I noticed a very small amount of oil accumulated at the bottom near the threads, however the spark plug itself had absolutely no oil on it. The car runs and drives perfectly fine as it should, I was just wondering if this was a common problem or even a problem at all? I thought that there were seal to keep the oil out so I figured maybe that one went bad, but then I read that the entire valve cover would need to be replaced, which I'm guessing is a huge PITA. Can anyone help me out on this one? I'm debating just ignoring it until a problem presents itself just because there's nothing wrong as of now, but I'm not sure if this is a bigger issue than I think it is. Any and all advice is greatly appreciated! Thanks guys!
