bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Wed Jun 01, 2005 8:26 am
I recently bought both an electric oil pressure and temp gauge. I had to run an extension off the block to a T-adapter to fit them, which I mounted to the strut tower. The pressure gauge was working working fine (more about this later,) but I never got the temperature gauge to work. The bottom of the temp gauge is at 140°F, and I know a stock KA doesn't get *too* much hotter. But the needle never leaves the bottom of the scale. I have convirmed that the gauge does work. The only thing I can come up with is that the 3' of stainless line might be cooling the oil enough so it isn't hot enough to register, because the line never feels hot after driving. Either that or I have a bad sender. For the pressure gauge which I did have working fine, I messed it up somehow in the attempts to fix the the temp gauge. Now, if the engine is under stress and the pressure is high, the gauge looks ok; but when it idles and the pressure falls the needle gets erratic. It can jump randomly +20 psi and fall back quickly, and sometimes it settles about 10psi low. I have gone over all the wiring and everything I can't figure out what I did. Any advice is welcome on either problem. Thanks in advance.
