Oil fouled plug in cylinder 2
halvorsenb
Car: 1995 300zx NA
When I changed the spark plugs on my 95 na z32, 5 of them looked like the one on the left, and the plug from cylinder 2 is the one on the right. Clearly it's got some oil fouling, just wondering the best way to proceed.
Thanks.
PapaSmurf2k3
Site Admin
Hey welcome to NICO!
Typically a plug that looks like that either has a bad wire/coil going to it, or has a leak somewhere, like a leaky injector or a valve cover gasket that is leaking oil down in there... or a piston that has some bad rings. You'd probably see/smell blue smoke out the tailpipe if it were the piston though.
I'd replace them and check it again in a thousand miles or so. Does it still run fine?
halvorsenb
Car: 1995 300zx NA
PapaSmurf2k3 wrote:
Tue Feb 11, 2020 6:54 pm
Yeah it doesn't seem to be causing any noticable issues. I'll have to check for smoke next time I start it up. Thanks for the reply!
PapaSmurf2k3
Site Admin
Good luck. Let us know how you make out.
NolimitZ32
Those also look like the wrong plugs for the VG, supposed to be extended.
