Oil/Fluid Types
Khronik
Car: Pearl White - 91 N/A 2+2 Auto (RIP)
Arctic White - 96 N/A 2+0 5spd (SOLD)
Aztec Red - 90 TT 2+0 5spd (DD)
- Megan Racing DP's
- Borla Catback exhaust
- CZP ECU Upgrade
- SZ High 5 Clutch
been checking out alot of posts about motor oil and transmission fluid changes
guessing alot of it is based on preferrence but please clarify me on these, and how much I would need for DIY
Motor Oil: Mobil1 5W-30 Synthetic (been using this) = 5quarts?
Transmission Fluid: Redline MT-90 = 3quarts?
Differential: Royal Purp or Red Line?? = ?
what have you found best results using......
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
vulcanrush
Car: 93 300zx n/a to tt
the capacity is only 3 quarts+? i thought it was 4 quarts+?
speedeast
I see where this has been debated over and over again. This is from an FSM. I have read that it is supposed to be 3 5/8 qts. I have read 4 1/2 qts, 4 3/8, 4 5/8, etc. Let me dig around. But a safe thing to do is start low and fill until the dip stick is satisfied.
[EDIT]
The FSM states the capacity in imperial quarts. 3 imperial quarts translates to 3.6 us quarts which is right about 3 5/8 us quarts.
Supposedly, 1990 models require:
NA: 4 3/8 us qts w/ filter, 3 7/8 w/o filter
TT: 4 5/8 us qts w/ filter, 4 1/4 w/o filter
and the 1991-1996 models require:
NA & TT: 3 5/8 us qts w/ filter, 3 1/8 w/o filter
Weight: 10w-30
So, there you have it.
Transmission took me slightly more than 3 us qts to fill; was dry. FSM says it requires 2.8 liters or 4 7/8 imperial pints. If you do the math:
2.8 liters = 2.96 us quarts
4 7/8 imperial pints = 2.93 us quarts
Differential should be (according to FSM) 1.5 liters or 2 5/8 imperial pints.
1.5 liters = 1.59 us quarts
2 5/8 imperial pints = 1.58 us quarts
They SHOULD be as follows: (based on '95 model)
NA: 1.3 liters or 1.37 us quarts
TT: 1.8 liters or 1.90 us quarts
What makes the transmission and differential easy is that they overflow when full.
