Oil flow direction at oil filter?
onosqv
Car: '92 240sx Vert
Does anyone know if the oil goes in the filter toward the outside "ring", then leaves the filter down the middle? or does it pump oil up the middle, then out the sides?
I'm trying to figure this out for oil cooler placement and possibly oil feed line running.
Car if it matters: 89 240sx ka24e.
Acuratechva
Car: Black Kouki
oil comes in from the side of the filter and then goes back in to the block through the center.
S14KoukiMonster
Car: 1997.5 Nissan 240SX LE 5spd.
Correct!!!!!!!!!!!!!!!!
onosqv
Car: '92 240sx Vert
Cool, the more you know THANKS GUYS!
