elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Oct 07, 2005 5:39 pm
Just wanted to post today (for anyone who might be searching for this down the road) that the Q oil filter needs an 80mm cap type filter wrench...
i changed my oil today in the Q, and try as i might i couldnt get any of our nice array of oil filter wrenches (the strap type) to work.... that cute little metal plate they put there so you dont get oil on your belts really gets in the way...... I went out to NAPA (ripoffs r us) and got one for $4....
Using genuine nissan OEM filters (the 60u00s), and mobil 1 0w40....
no reason posting this, but unless you had some sort of goofy offset strap wrench or something, the cap ones seem to work very easily and effectively!!!!
also wanted to remind you guys of the ATF trick, add 3/4 quart of ATF (m1 syn preferred, i used conventional though) to the engine oil (hot, i drove my car for an hour on the freeway), and let the car idle for 15-30mins (I think i let mine idle for 20 mins, started it up and made a few phone calls), and then drain IMMEDIATELY after turning the car off..... The trick is to drive the car much, preferably not at all.... ATF cant take the kind of temps that regular oil can, so i prefer just to let the car idle..... you wont really be doing any damage per se, you will just really be cancelling out any good things the ATF may do, if it gets too hot youll just turn the ATF into varnish....
Either way, for an extra $2-4 per oil change you can clean your engine effectively and safely with this trick
