I've finished rebuilding my motor and can't figure this one out. I tried the OEM gasket for it, which poured oil. I tried putting RTV on the gasket to help it seal, same thing. So I tried using a thick bead of RTV, which worked for a while. I let it idle for 15 minuets with 15w-40 (added zinc to help cushion the bearings). Then changed to 10w-30 to drive around with. It had about 60psi of oil pressure while driving and about 30psi at idle. After I drove it for 14.7 miles I lost oil pressure and when I pulled over I found the oil filter tree was leaking... Again. Does anyone have any Idea of how to fix it. I'm ordering a new OEM gasket for it today.
