Oil Filter
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
Any know or know of the cross reference part numbers for the Versa oil filter? Thanks.
Bubs daddy
ABS, CVT
Never mind. Just called checker and they have all kinds there for Versas.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
And for those who haven't checked with their local parts stores, it's the same filter as on the 3.5L V6 Maxima.
Bubs daddy
ABS, CVT
Got one. Man, that's a teeny filter.
Had to get a new filter wrench because the two I had were too big. Got the end cap type with the 1/4 inch socket. Works great. 4 qts of fresh Mobil 1.
Ahhhh...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Ever Victorious wrote:And for those who haven't checked with their local parts stores, it's the same filter as on the 3.5L V6 Maxima.
Yeah, I think Nissan does this on purpose. There is at least one other Nissan engine (I think it's the QR from the 4 cyl Altima and Sentra SE-R) that uses the same filter. Smart move on Nissan's part.
JPack
Any idea who makes the Nissan-branded filter? I'm wondering because Honda for instance, uses a rebranded Fram filter for the current Accord.
bronxnino
Car: 2007 Nissan Versa 1.8S
While we're on the subject, I was wondering.
Should I be replacing the oil drain plug everytime I change the oil.
This isn't my first car and I've always changed the oil in my vehicles myself however, i read somewhere that the oil drain plug should be changed with every oil change.
MIdnkight-lude
when i looked around the v6 filter were the only one that work. So if you found one for a 350z, go a head and use it, that what i did.
Bubs daddy
ABS, CVT
Quote »Should I be replacing the oil drain plug everytime I change the oil.[/quote]Nah. Get a new crush washer every so often. It's a perfectly good bolt.
Modified by Bubs daddy at 5:53 PM 1/30/2007
Ever Victorious
'73 AMC Hornet
[QUOTE=Bubs daddy]
[QUOTE]
I'll go a little further than "every so often" and say every oil change. Crush rings are so inexpensive... usually only about a buck, give or take a few cents... that it makes sense in the realm of better safe than sorry to just buy 20 or so, and keep em around for oil changes.
MIdnkight-lude
unless your like me, and you end up getting a magnitic drain bolt. i did my own oil change at the shop i work for, and they had tons of the magnitic bolts, so i grab one, and installed it, i dont know if it works or not, but it was cheap, so i went what the heck.
Clipsed
Car: 07 ALL BLACK Nissan C11ST, 01 Mustang GT Vert, and 94 Suzuki Sidekick JX 4x4.
Has anyone heard of this special adapter for oil filters? It is a magnet, and attracts all the magnetic particles that could cause harm to your engine. They were selling them on another forum, I think the Mustang Forum I belong to. I will have to find it, it looks like it is something that would actually work not some bs. I will find the link and post it on here so you guys can see it and tell me what you think.
Ever Victorious
'73 AMC Hornet
Well, there's more that can damage your engine than simply magnetic or metallic particles. A good filter to begin with is the cure to these woes.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Clipsed wrote:Has anyone heard of this special adapter for oil filters
I've seen magnetic drain plugs before, but I hadn't heard of magnetic filters.I suspect the drain plug would do more good, since the magnetic particles are likely to sink to the bottom of the pan and not circulate with the rest of the oil.
Clipsed
yea I have seen those too, but this goes between the filter if I remember correctly.
Bubs daddy
ABS, CVT
Quote »magnetic particles [/quote]??
