osofasts13 »
https://forums.nicoclub.com/osofasts13-u11703.html
Sun Feb 01, 2004 9:13 am
well yesterday i went upon changing my oil, alittle bit over the 3000 miles but oh well who can get that timing perfect anywase. so i took off the oil plug, then went upon taking off the oil filter. at first i used a oil filter cap (socket style), kept slipping, so i switched over to a wrench type, it ripped a hole into the filter. so i'm like what the f@ck, i call autozone and they say use a screwdriver and hammer to try to twist it by prying it sort of. i do that and it rips my filter even more. now my oil filters f@#ked, all tore up and hasn't even moved yet. i go and by a different style filter remover, the circle strap style that tightens as you move it, i barely have any filter left to attach it to and that didn't work out to well. so now i'm stuck with a oil filter that is all tore up at the end, and hasn't even moved yet. what do u guys think happened, could it have gotten so hot that it welded it self on to the block. i have no idea how to take it off, no room, and the end part of the filter is about gone. :help this is on a s13 with the ka24de.:help IT HAS NOT MOVED ONE INCH YET, AND I AM TWISTING IT THE RIGHT WAY, TO THE LEFT THAT IS, COUNTER-CLOCK WISE!!
